Pagina 1 di 2
Cupolino regolabile
Inviato: venerdì 11 gennaio 2013, 21:40
da brucaliffo
http://www.apriliaforum.com/forums/show ... ost3289634
presto in vendita su
http://www.palmerproducts.co.uk/
This Screen Adapter Kit is designed to address the common issues of wind, noise and turbulence to significantly improve the bikes cruising and touring ability, providing the rider with a much improved riding experience.
The Aprilia Screen is quite a good design (although positioned incorrectly) so we recommend this in conjunction with the Adapter Kit
The key to optimum performance is the forward position of the screen, just enough to allow air to pass underneath, relieving the vacuum created behind the screen - the main cause of turbulence.
This forward positioning also provides essential airflow to prevent visor misting and fogging.
Provides 60mm of vertical travel with up to 15 Degrees of tilt.
The fitment of this kit requires NO MODIFICATION to the bike and fitted in minutes.
These unique and original Kits have become extremely popular amongst the Adventure Rider community all around the world!!
The Benefits of this system also include:
* Kit comes Preassembled, ready to mount to the bike using existing locations.
* 12 indexed positions (height and tilt angles) - giving all the range of adjustment you'll need.
* Top grade Laser-Cut Stainless Steel brackets and Stainless Steel fasteners.
* Kit comes complete with all hardware and tools, plus spare sundries.
* Allows cleaning access behind the screen without removal.
* Can be fitted in approximately 15-20 minutes.
* On-line step-by-step detailed digital photo instructions.
* Tool-less upgrade available for quicker screen adjustments.
Re: Cupolino regolabile
Inviato: venerdì 11 gennaio 2013, 21:46
da maisoon
mmmmm... abbastanza complicato..
Inviato: venerdì 11 gennaio 2013, 21:58
da ElCaimanDelPiave
Bruco, possiedi la lettura del pensiero???
Proprio oggi mi ero messo a cercare tutte le discussioni a riguardo perche' mi sono messo in testa di realizzare un accrocco del genere per la moto di Nittone, che essendo alto la bellezza di 192 cm non e' soddisfatto della protezione del cupolo originale, e mi ha commissionato la ricerca di qualcosa di piu' protettivo.
Ma dato che io mi chiamo Caiman e le strade facili non mi appassionano, ho osservato bene il cupolino di serie e ho iniziato ad elaborare una soluzione per renderlo regolabile.
E questa che hai postato si avvicina parecchio all'idea che avevo io.
Avevo realizzato un accrocco per la pegaso strada, che permetteva di alzare il parabrezzino di serie di un buon 10 cm. E funzionava alla grande, solo che non era bellissimo.
Beh, anche questo non e' bellissimo, ma basterebbe opacizzare la parte bassa del plexi per rendere meno visibile il meccanismo.
Rispetto a quello americano postato anni fa, che era parecchio brutto perche' sporgeva molto in avanti, questo mi sembra davvero piu' sobrio.
Non sono riuscito pero' a capire quanto costerà.
Ma mi sa che invece che mettermi a trabaccare con barre e lamiere di alluminio, trapani, seghetti e carta millimetrata, prendo questo già pronto e passa la paura.
MA, c'e' un MA: le foto sono dell'orecchiuta. E per l'altra? Se non c'e', nulla di fatto.
Inviato: venerdì 11 gennaio 2013, 22:14
da giancarsenio
Bella l'idea e il meccanismo...curioso del prezzo però
@Caiman: se non dico un minkiat@ i 4 fori di fissaggio frontale sono gli stessi tra le due versioni.....
Inviato: venerdì 11 gennaio 2013, 22:28
da Gianlu-Gianlu
Inviato: venerdì 11 gennaio 2013, 22:34
da ElCaimanDelPiave
Inviato: venerdì 11 gennaio 2013, 22:40
da Gianlu-Gianlu
No no, hai frainteso.........
Intendevo perchè non l'hanno chiuso sul forum inglese dato che a me e al bruco ci hanno bloccato con il kit biellismo
Inviato: venerdì 11 gennaio 2013, 23:17
da ElCaimanDelPiave
Ok, ma in effetti anche questa discussione andrebbe accorpata con una già esistente, e l'ho trovata, nella quale si parlava dello stesso argomento:
http://www.apriliaontheroad.com/forum20 ... regolabile
Aperta da chi? Dal Brucone!
Inviato: sabato 12 gennaio 2013, 0:45
da Aleevo
Minkia che lavoro brutto !!
Senza contare lo spazio libero tra plexy e plastica cupolone ..
Terribile..
Inviato: sabato 12 gennaio 2013, 1:02
da ElCaimanDelPiave
Aleevo ha scritto:Minkia che lavoro brutto !!
Terribile..
Immagina il meccanismo coperto da una schermatura. Immagina tutto verniciato in nero.
Immagina questo coperto di grano. Immagina i frutti immagina i fiori, e pensa alle voci e pensa ai colori...
(F.Guccini)
Lo spazio tra cupolino e plexi, secondo la descrizione dell'artefice, e' funzionale alla riduzione delle turbolenze (e ci posso credere dato che in molte moto e' adottata la stessa soluzione).
E poi non sporge così tanto!
Inviato: sabato 12 gennaio 2013, 6:38
da Homer75
ElCaimanDelPiave ha scritto:Aleevo ha scritto:Minkia che lavoro brutto !!
Terribile..
(F.Guccini)
Adoro Franceso Guccini
E' da quando ho acquistato la Capo che sto studiando una soluzione simile ma non mi è ancora arrivata la scintilla giusta!
Il tipo ha fatto un bel lavoro ma mi sa sporge troppo in avanti.Poi a che servono i i due occhi da cinese davanti?
Io avevo provato una volta con due binari da cassetto molto più sottili ,ma non essendo allineati i punti di attacco, ce ne volevano 4 e il risultsto finale faceva abbastanza schifo!
sono curioso di vedere gli sviluppi!
Inviato: sabato 12 gennaio 2013, 15:49
da bugio
Miseria se è brutto !
Inviato: sabato 12 gennaio 2013, 21:55
da ELBANO
Personalmente non piace....Preferisco il mio x-creen...
Elbano
Inviato: sabato 12 gennaio 2013, 23:07
da gio70
Sicuramente sarà funzionale ma anche a me non piace
Inviato: domenica 13 gennaio 2013, 12:00
da Optimus Prime
idea buona
realizzazione esteticamente discutibile
