Azzeramento TPS
mauro1375
Moto: Aprilia Caponord etv 1000 abs
Azzeramento TPS
Messaggio da mauro1375 »
Salve a tutti...posso fare solo l'azzeramento TPS? Che cosa sarebbe? Grazie a tutti e buona serata
Mauro Caponord 1000 abs
findejs1310
Moto: etv1000
Re: Azzeramento TPS
Messaggio da findejs1310 »
Hi everyone :ciao:
Can you write me how I can do reset TPS.?
Step by step please. :impara:
Thank to all very much
Jura
Yak
Moto: ETV Caponord 1000 2003
Re: Azzeramento TPS
Messaggio da Yak »
1. You need tuneEcu :alpc:
2. You read the guide :impara:
. :o :impara: :-?
After
1. Connect tuneEcu
2. Start engine
3. Check all if ok
4. When the engine arrive at temperature shut-down
5. Reset tps with tuneEcu
6. Reset another time tps with tuneEcu
7. Start the engine and dont touch the trottle
8. Wait 10 minutes for the ecu learn the dates
9. Shut-down the engine.
Finish
Sorry but my english as no good.
Bye :friends:
findejs1310
Moto: etv1000
Re: Azzeramento TPS
Hi my friend
Thanks for your answer. :italia:
I have Tuneecu and I reloaded maps and deleted mistakes .Is not problem for me.
But your step 4.5.and 6. is important for me.
I dont know if I have to switch ignition button to "OFF" and then "ON" after reset TPS and then start engine.
And 10 minite?? Is it too long or no?
I saw a lot of manuals about reset TPS and each was different.
Best regards
Jura
mcr
Re: Azzeramento TPS
Messaggio da mcr »
findejs1310 ha scritto:
mercoledì 11 luglio 2018, 23:19
Hi my friend
Best regards
Jura
Hi Jura,
warm up the engine
turn off the engine, then turn on the key only and reconnect Tuneecu
Reset TPS
Start the engine and wait 1 minute at least with the engine running, the idle speed will change a little, don't worry, after 30 seconds it will be more stable.
Turn off the engine and be happy :cn:
Yak
Re: Azzeramento TPS
Messaggio da Yak »
Grazie MCR, il tuo inglese è sicuramente meglio del mio e le spiegazioni sempre precise :friends: :ok:
findejs1310
Moto: etv1000
Re: Azzeramento TPS
Thanks friends. :salta:
Jura
augustox
Moto: caponord rr
Tel: 3405036707
Re: Azzeramento TPS
Messaggio da augustox »
io l'azzeramento tps lo faccio con l'app tuneECU
