montaggio relè pegaso 95
giosamma
Moto: PEGASO GA
Località: Cava de' Tirreni (SA), Martina Franca (TA), Ostuni (BR)
Re: montaggio relè pegaso 95
Messaggio da giosamma »
perfetto matek...
Matek ha scritto:
Now is fine,14,4 V,before 15V :( ,but thanx to sergio,paolo,and giosamma i fixed the problem,grazie!
:ok: Matek
Matek
Messaggio da Matek »
Hey boys,it is normal that relais is warm?
Matek ha scritto:Hey boys,it is normal that relais is warm?
:nono:
should not be hot
how many amps is it?
Matek
it is not hot,only warm,it is 30 amps.
Matek ha scritto:it is not hot,only warm,it is 30 amps.
30 amps is O.K.
Matek
it is okay then that is warm? voltage rectifier is also warm,but that is normal.
Matek ha scritto:it is okay then that is warm? voltage rectifier is also warm,but that is normal.
Mine is not warm is cold
Test with another relay that costs about 5 €
if it is the same warm do not worry
Matek
okay,i will try with another relay then,i think that is good this way,maybe is relay not good quality..thank you!
and one more thing-can anyone explain me how does this all works now,i mean,relay and new wires connected,i dont understand what we make with this new installation :oops:
passero72
Messaggio da passero72 »
X Matek
Nella foto che hai postato il relè mi sembra sia troppo vicino al regolatore. Io l'ho posizionato tra il blocco sella e il relè frecce....... Ci sta perfettamente e con un pezzo di camera d'aria tagliata a misura non vibra ed è protetto anche dall'acqua.
Lamps, Paolo
Aprilia Pegaso 650 '93
Suzuki DL 1000 '05
Matek
Ciao Paolo! Can you make a photo,that i see how you have install relay? Grazie!
In a nutshell
The problem is in the ignition switch that with the passage of kilometers breaks
when it breaks too much current is sent to the battery
Some people AOTR have long studied the problem and have it solved by mounting the relay
giosamma
Moto: PEGASO GA
il mio relè non riscalda in quella posizione ... forse perchè non ho fatto ancora una prova su un tragitto lungo .. cmq questa info la tengo a mente..
Ultima modifica di giosamma il giovedì 17 aprile 2014, 15:08, modificato 1 volta in totale.
passero72
Matek ha scritto:Ciao Paolo! Can you make a photo,that i see how you have install relay? Grazie!
Suzuki DL 1000 '05
Matek
Grazie Paolo!
